It's the ones who refer to BS7671 as a 'Guide', that ever so slightly makes my toes curl.
No it's not, it's a British Standard which one needs to comply with.
All the other books, as already pointed out, are guides to, and help with, using BS7671.
Mr S, you're wasted on the Part P debate. Expand your horizons and get stuck into ambiguities in the regs and remodelling of the certs.
Ok Biff
you buy a class II light fitting, what method of protection will this fitting offer from electric shock ?
True Archy, but unfortunately because of the nature of BS7671, guides or interpretations are necessary as a way to acheive a common standard, but it doesnt seem to be helping in this instance.
Thanks For posting this I have always thought that it should be N/A but have been told loads of times that it refers to Bathroom fans and down light and gone through these arguments in this thread, I use the tick sheet when interviewing sparks it gives me a good guild if they are blaging me when they try and explain what they think various checks are referring to
71 posts from experienced guys regarding a tick box! Just goes to show how the regs and certs are flawed and open to interpretation
I've only skim read this so far and I'm not re-reading 72 posts...
Are we talking about the SoI on page 395 of the BGB here?
If so, if an install had SELV and DI equipment within it, them boxes would get ticked.
The clue is the heading, "Methods of protection against electric shock".
I wouldnt say flawed, but open to interpretation definately, cos they are the requirements to be met to achieve conformity with statutory documents, and are themselves interpretations of CENELEC harmonisation documents and as such need to be interpreted by other guidance notes etc...hope that makes sence :1eye:
