Does anyone know of an 80a type b double pole MCB?
I can't find one anywhere.
You get a 2-pole 100a isolator which is the same form factor as a 2-pole MCB. Look at the Hager SB299 for example.
You would still need an enclosure.It's for isolation of meter tails with fused protection. But limited space, so MCB would fit better
Not connecting swa. As I posted its to protect meter tails.
That click one looks smaller, I may be able to fit that in, thanks.
