Hey Everyone,
I'm after some advice if possible... I have recently bought my first home and I'm having issues with one of the double sockets.
There has been no power to it since I have moved in, I changed the physical front socket to see if that would rectify the issue, however it still doesn't work. I have checked to make sure nothing has tripped just to cross that off the list.
Now the struggle I'm having is finding where the wires go too. As I don't want to rip the carpet up and remove floorboards if possible.
I have checked everywhere in the house to see if it's wired to a switch as there are only 3 wires in the backbox (Brown, blue & earth) Every other socket in the house works correctly. Is there a way I'm able to trace the wires to find out where they're routed too without removing the carpet? I should add for clarification, the bedroom is upstairs and the cable comes into the back box from the underside, suggesting it doesn't come from the loft. ( I have been up there and I can't see any power cable that runs to the wall where this socket is, however I can see a power cable in the loft that operates the double socket on the opposite side of the bedroom.
There is a plug directly under this plug in the living, which I removed to check if there was any sort of additional wiring that may have powered the socket in the bedroom but there is not.
Thanks in advance!
Thanks in advance!
