Darren Purdie
Hi Guys,
I need some advise on suitable down lights for my newly renovated bungalow.
We are looking to run three centered mains fitted down lights down the length of the hallway ~around 1.5m apart.
The ceiling itself is a single sheet standard plasterboard which will eventually have kingspan and loft flooring installed above it.
Although we want to go down the LED bulb route I really need to understand what we should be going for with regards to the actual light fitting.. Do we go for fireguard units? If so can the King span sit on top of this or would i need to cut out a hole?
Thanks,
Daz
you can fit fire rated or non fire rated. even though LEDs don't run hot, a clearance of at least 2" all round, and above is required. leave gaps in the kingspan.
Thanks for the reply telectix.
I was going to go with the standard firerated units that i saw in b&q but i started to worry and ended up reading too much into it.. 30/60/90 minute rated lights and what would be suited to my ceiling etc..
Are their any brands that you would recommend from your experiences?
Thanks again! :)
Daz
have you got a branch of screwfix near you? if not, order a catalogue on line or by phone. electric center do a cheapish but quite good quality range. best to avoid the ones that hold the lamp in with a circlip. some LEDs won't fit right. the twist/lock bezels are the way to go.
Whilst many people use the rule of thumb that fire rated fittings are only required if there is living accommodation above, I personally always fit them.
Your existing ceiling is a barrier to prevent fire and smoke spreading, and when you cut holes in it, you are reducing the effectiveness of that barrier. Fire rated light fitting contain an intumescent seal which will expand and prevent the spread of fire for a longer period. No one wants to think of the worst happening, but at the end of the day, is it worth NOT fitting them just to save a few quid?
agree with what you are saying, but there is a huge hole there between the hall and the upstairs, which will allow the spread of fire , no matter what lights you fit. it's called a stairwell.
