It's switched from just inside the front door. There was an existing 2g switch there, one side previously controlled an outdoor light where the solar powered light to the left of the front door is. I reused this switch. The construction is timber frame, so I was able to rod the cable vertically up behind the plasterboard, then straight through the wall into the canopy void. The only damage to decor was one 16mm hole in the plasterboard.Where is it switched from and how did you run the cable?
