- Reaction score
- 165
Extension consisting of a kitchen and dining room with a sloped ceiling. Directly above the paperboard will be 160mm of kingspan with a 80mm airspace above. The customer wants downlighters and I was planning on boring a 110mm hole in the kingspan before the paperboard goes up. Obviously this is going to compromise the insulation value but what else can I do? There's no option to lower the ceiling! Can I use the standard downlighter ring or do they need to be firerated or might I be better to use an LED fitting? Only problem is that the lights need to be tilts as the ceiling is sloped.
Cheers in advance.
Cheers in advance.
