Discuss DPDT Switch in the Canada area at ElectriciansForums.net
S
sparkamarkatron
Hi there,
Does anybody know where I could get hold of a double-pole double-throw switch (also known as a four-way-switch, crossover switch and change over switch)? I would like to control a set of lights with three switches, and it is possible by using two SPDT switches at each end (like in a two-way switch circuit) and putting a DPDT switch in the middle (which would swap over the travellers). Does anybody know where I could get hold of such a switch? It would only need to be rated at 10A, but it would need to suit British Standards. I want it to look like a rocker light switch too if possible, not a big red isolator switch.
Thanks.
we call them intermediate switches. so waht your trying to do is wire a 2 way and intermediate system. For your information, you can use as many intermediate switches as you want.
you can buy them at any electrical wholesalers
Aaah, yes. This would appear to do the trick. I thought intermediate was just a two-way switch with centre off for some reason - intermediate being the off setting in the middle. However, I appear to be wrong. Thanks a lot!
You are using a mix of US and UK terminology and they do not necessarily match up.
In the US an intermediate switch is a four way switch. UK two way switch is, I think a US three way switch.
Reply to DPDT Switch in the Canada area at ElectriciansForums.net
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Hi, I want to put downlights in my fire surround - possibly 3 but more likely going to be 2. They are 0.4w LED lights. I have a 12v 8w LED driver...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
I'd like to wire a six pin DPDT rocker toggle switch to turn a low voltage LED fixture on and off. The rocker toggle switch I have is an...
