Discuss Drilling downlights in horse hair plaster in the UK Electrical Forum area at ElectriciansForums.net
Did some a good few years back in a lathe and plaster ceiling. Nightmare needed to change the hole-saw ever couple of cut as it seemed to blunt and as soon as that happened started snatching in the lathes and busting up the plaster. They were Starrett so not cheap ones.
Cutting the hole is just part of the battle: Some downlights just never sit right in lath and plaster ceilings (typically cheap ones with weak springs) . I have used Aurora EDF Pro's in L+P, and they have worked well.
Not something I would try! As above it is notoriously hard stuff to deal with as it can be very thick, hard to cut, but crumbles if you look at if funny, and makes a hell of a mess.
If I absolutely had to do it I would follow @Taylortwocities route.
Whatever you do plan for redecorating in some form! :(
Easy.....ish.....?.....just make sure the drill bit is new/sharp and is spinning fast when it hits the ceiling....don’t push the bit through either let the cutter do the work, if you push it though you’ll find some lathe that’s been cut through already will bend with you pushing it and will snap further down outside from the hole you are trying to achieve......we do it regularly down here as there is a lot of victorian housing stock.....never nice but it can be done just take your time.....AND wear a mask and googles!
Reply to Drilling downlights in horse hair plaster in the UK Electrical Forum area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
So I’m an apprentice and only get to do downlighter jobs as foreigners at the weekend, but they’re typically added when the customer no longer...
Quick question to electricians - I want to add metal-plated sockets to newly plastered walls. The electrical wholesaler advised that newly...
Hello, We changed plans with lighting in one zone. Now instead of 4 downlights (square shape of 1400mm side) we want a chandelier. Since...
Hi Guys We 'have to' fit couple of these on a job in new year, hate them ! Anyone found any easy ones to fit ? Maybe have a that come with...
