Discuss Driver door wiring on 99 GMC Jimmy in the Auto Electrician Forum area at ElectriciansForums.net
I replaced a door on a 99 GMC Jimmy with a old 98 door and the wiring was a little different, the 99 had 15 color coded cables and the 98 had just 10, I matched the colors that I could and taped the other 5 cables. Once I put the door back together I could only adjust the mirrors and lock/unlock the truck. None of the windows work now including the sunroof. All I really need is the two front windows to be functional. Im sure it would take a Auto Electrician little time to figure out.
Take the original 99 wiring loom from the damaged door and fit it to the new 98 door you have used,
should be much quicker than trying to figure out the purpose of each cable.
Reply to Driver door wiring on 99 GMC Jimmy in the Auto Electrician Forum area at ElectriciansForums.net
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
My GF's daughter's 2010 four-door Elantra had a broken window regulator at the front passenger door. I replaced it. To do so, I had to disconnect...
Awful time of a new installation by an idiot! He spent most of his time with his phone attached to his ear held between his shoulder and face...
5K
Hi: I'd appreciate any words of wisdom to diagnose the power locks on my 1998 F-150. Symptoms: -The key fob works to lock and unlock both doors...
I have a Bell Systems intercom on a perimeter gate fitted with a maglock. I have an additional access control keypad on my front door with another...
