S
sparkyjohn1
I know this may have come up a fair few times in the past, but I've just been to a clients house, to quote for wiring their new loft extension,,. I found that the structural steel used as the framework has been bonded back to the C/U with a 10mm Earth Cable in TWO places..!!
The steel work itself is purely for structural purposes for the extension, sat on brick and mortar and does not have an earth path, literally 2 floors vertical from the ground,, Also it is not likely to be exposed when the work is completed..
Is this bonding unnecessary? As I cannot see how it benefits the earthing system for the property . I would understand if the steel was grounded with an earth rod, and bonded to C/U creating a 'proper earth path' but there is no rod present.
Any feedback would be appreciated , thanks
jd
By the sound of it no it isn't needed but the only why to find out is test it back to M.E.T
If its a new loft extension ,it may be worth asking whoever installed it , what their thoughts are and why and is there any paperwork for it,,
Thanks for reply, but in my humble opinion, worst case scenario if for instance you lose the main supply earth into the property,, for any reason,, i think it is just creating extra metal surfaces which could become live under fault scenario, with no chance of it escaping. (especially if water main and gas main are plastic entering the property,). there would be no way of fault current dispersing to ground.. surely it is more of a hindrance.?? R.C.D would not necessarily trip , because the fault wouldn't be a 'leakage to earth' , because it wouldn't leak anywhere,,, it would just stay there.. Please correct me if I'm wrong, here,?!
The steel is likely to introduce an earth potential by virtue of being in contact with the ground. The idea of bonding it to the electrical earthing system is to create a zone in which all metal work likely to have a potential will all be at the same potential.
Therefore in the event of a fault which causes a rise in potential on the earthing system to say 100v....all bonded services and metalwork will also rise to 100v.The diference between 100v and 100v is 0v,hence within that zone there is reduced shock risk for persons simultaneously in contact with an earthed (say) kettle and a water/gas pipe or structural steel.
I would understand if the steel was grounded with an earth rod, and bonded to C/U creating a 'proper earth path' but there is no rod present./QUOTE]
you have not stated what earthing system is present at the property . if TN it is going to be far superior to an earth rod . (unless installed by Engineer 54)
you lose the main supply earth into the property/QUOTE]
just creating extra metal surfaces which could become live under fault scenario,/QUOTE]
What are the chances of the 2 separate faults happening at the same time , slim to none ..
Also it is not likely to be exposed when the work is completed/QUOTE]
work is still ongoing so surely the contractor who installed the bonding is still on site ?
A few things dont add up in this post .
disconnect the bonds and test to see if they are extraneous ...
I understand the logic behind earthing and bonding,, and fully conversant with the theory behind it . But in this instance, the steel ISN'T in contact with the ground,., and it isn't likely to be touched when the work is completed.. it will be concealed.. I will try and find out some answers why the builders felt it was necessary to do it.
Probably because the section in 7671 concerning main bonding lists structural steel,they therefore assume this is set in stone. What they miss or more likely fail to grasp is the term 'extraneous' also used in the same section.
It's also the reason you often see heating pipes main bonded in properties where the entire system is within the building.
Love it, keep it locked up lol
The Supply is an Over head TNCS., with 16mm coming from Neutral/Earth Terminal at Incoming supply,,, All how it should be.. , I will seek some answers from the builders . thanks for the feedback folks.
Good luck with that, try talking in baby language you may get a reply or two, you could point at the ground whilst taking a leak against a wall, they may respond to that lol.
yeah, i know what you're saying mate,, most builders aren't very intelligent, just big lumps, all brawn and no brains,, and don't give a ---- about other trades..,, And thanks 'wirepuller' you got it spot with the extraneous ,. guessing they use what ever they can find sometimes,. It annoys me when they go on a 3 day part P course and reckon they know everything,, when some of us have been to college for 5 years...
....and this is why you TEST it to find out!!Saves all the guesswork and fannying around asking for "opinions" which you don't want - you want FACTS and YOU are the only one in the position to get those facts by testing it!
Test it, even if the steelwork is sitting on raised concrete, brick/block plinths, you may well be surprised just how porous building materials can be. I wouldn't mind betting that there is a decent chance that the value is below the 22/23K ohms, especially over time!!....
