Discuss earthing system question in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Hi guys,
I`ve just done some minor works in a property. Thing is I cant work out what earthing system the property is.
The 16mm earth disappears though a party wall with the incoming supply conductors.
There is no earth rod or overhead lines I can see. The property is at least 50 years old.
Anybody come across this before?
Cheers
measure the pfc L-N and L-E. if they are the same, chances are it's pme.
If you can get access to next door you may find where the tails split out from the service head. The next street to me was done like that, one service cable to every pair of houses, tails looped through to next door with fuses in each property.
Reply to earthing system question in the UK Electrical Forum area at ElectriciansForums.net
Went to a house to extend a circuit and upon doing the minor works I couldn't figure the earthing system. There was no DNO cutout and L and N came...
My mate has family in Southern Ireland and he has been over there a couple of times this year helping them renovate a property. He has been...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Shop with no earth coming from head, overhead lines in sight everywhere - definitely no earth from the DNO. Two 10mm earths going into the DB...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
