Discuss EcoTec Plus 424, VR66, VRT350F - Y system 3 port valve problem in the Central Heating Systems area at ElectriciansForums.net
P
Peterppp
Hello, I am new here but desperate for help as this is first time I am stuck on regular boiler Y system wiring. I have installed EcoTec Plus 424 with clipped on VRT350F and control centre VR66. I have wired all as requested in manual and get problem with 3 port valve. It get's stuck in either HW (standard) or CH, i cannot get the valve to go to mid position even when calls for both water and heating. Firstly i thought it was something wrong with the valve - replaced, nothing. Can this be an issue with the control box itself or the programmer?
I hope someone's here had "pleasure" with both these as this is my first time with them. I usually use Honeywell wiring centre which works just fine - but customer grrrr
What do all those numbers mean?
Is it a diverter valve or a mid position valve?
Does it give priority to DHW and change over to heating once the cylinder stay is satisfied
Reply to EcoTec Plus 424, VR66, VRT350F - Y system 3 port valve problem in the Central Heating Systems area at ElectriciansForums.net
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi there, the heating system I am working on has 6 zones and valves for each zone which was working fine with one boiler and one pump. some rads...
Hi people, I’m new to the forum, first post so here goes. I’m wiring a heating control system and at the moment the customer wants as follows; A...
Hello Guys, I was wondering if any of you nice chaps could lend me some advice. So I have an open vented heating system with a 3 port valve...
