B
Baker1988
Hi hope every one is having a good weekend.
I have recently started a job with a can who do eicr's/foxed wire testing and as I have only been qualified 2 years and worked mainly in commercial new installation so I have not had much experian in domestic eicr's. They are starting to train me by going around with the boss to the jobs but he has given me some examples and asked what I would do and one of them was "you go to a house and there is a plastic consumer unit with mcb's but has no rcd protection, the cables are buried into the walls" I think I would recommend a board change as the cables buried into the walls will probily be less than 50mm and also if I remember correctly in amendment 3 all cables going through the bathroom need rcd protection so would recommend a board change. Not that it will definatly need it as just because it is not not comply with current regs does not mean it is unsafe that's why it is recommended.
I could be totally wrong but that's why I am asking. If i am totally wrong can I ask what you would recommend a board change for?
