Is Google broken? There's several suppliers listed if you search. As far as quality goes it's not your problem if you're working to a clients spec.
wow, what an arse. If you can't be bothered to answer constructively then just **** off. Firstly "stockists" on google may s
ay they stock them but dont & you find out after you order that you wont get the fittings for weeks. I was looking for the names of reliable stockists. Never mind, I'll start phoning round tomorrow, nearest Ross's & CEF 50 miles away, nearest Edmundsons 140 miles away.
As for quality not being a problem, I dont like to use fittings that, say, might catch fire after a week, so I would point them in a different direction if other, reputable contractors have had problems with certain brands. You carry on your way tho.
Zero from me Bob.......with an attitude like that!!!
Must live in the middle of nowhere then, never heard of mail order either.
Bought them from here before ELAN LED Fire Rated Downlight Fixed
Never again didn't like em
It's never a good idea to call a Moderator an arse.
I always think it's better to call the arse a moderator. :joker:
(just kidding Marvo .... honest!! )
thanks, at least its constructive to hear someones views on the fittings. Yes, rural highlands so middle of nowhere, Small independent wholesaler locally but he's unable to source hence my request for decent suppliers. Use the internet quite a bit for orders but always try to use local if I can - use him or lose him.
Anyway thanks again. Think I'll try & persuade them to use Halers, have at least used them in the past & were fine.
What's that little outburst in aid of?
Firstly foul language will get you banned.
Secondly you request supplier info and you don't state your location in the post nor in your personal details below your avatar so Google is the best option I can suggest.
Thirdly my point about the quality not being your problem is valid. If the customer has specified them then they did so for a reason. If they're British Standards approved then there's no reason not to install them. If you suggest an alternative and there's future problems it will be you problem instead of the customer's.
Fair enough, perhaps a bit OTT on my part, apologies.
