T
TPES
If you were to be wiring a very large elderly care home with a hospital bult into it, what main factors would you need to take into concideration?
and what parts of BS7671 would be most important to follow?
Im talking out of the ordinary from general domestic work, including things like..
fire alarms, emergency systems, ventalation, wiring methods, RCD protection?
what would be needed by an electrician to meet every applicable building reg and wiring regulation for a place like this to be snag free when done?
And where would I find one of these for this one off job? Have you guys ever used one? Is it not something with alot of carefully thought me and my partner could plan our self?
Along with designing the electrical installation to BS 7671 you would also need to comply with BS 5266 & BS 5839 for your fire alarm & emergency lighting installations. Then you still need to comply to all the relevant building regs.
The design of a ventilation system can also be complex with all the air flow calcs required.
If you do it good luck to you but personally i wouldn't feel comfortable doing a design to that scale.
I would speak to a chartered surveyor and let him point you in the right direction to find the help you need.
Cheers..........Howard
Cheers for the advice chaps..
I've been told that some wholsalers offer a service where they do all your drawings for you on a scaled plan on the understanding you will buy all your materials from them.. anyone ever heard of this?
Im not sure what detail they go to with this.. would they design it after speaking with the customer on ther requirements
CEF have done a couple of drawings for my mate a few years ago, I seem to remember that they did some design. Not sure if they still offer this service.
An architect should be able to help with the design.
I look after all the maintenance in a couple of and there extraction systems are a nightmare especially in the common areas and common area toilets.
Not sure if you are competent to install and maintain a fire detection system. The care home insurers will probably want someone who is to install the fire detection system.
Also you will require an emergency call point (orange ceiling pull switch) in each of service users the bathrooms and bedrooms.
Another common feature they have in care homes is electric hoists above baths so you will probably need to allow for that.
The electrical installation will be straight forward, but I would be uncomfortable in designing fire systems, ventilation extract system (especially in common areas) for this project.
Ian
