Discuss Electric Cable & Gas Pipe In Same Trench in the UK Electrical Forum area at ElectriciansForums.net
Is there a specific regulation (electrical &/or gas) about running gas pipe & electric cable in same trench in a garden? Can it be done, if so are there any specific requirements?
Have been lucky to visit quite a few european countries, in the Netherlands they had combined service trenches/tunnels in the road which you could access via a man hole. had to stoop a little as they are about 5 feet high and about a single bed wide. inside were pipes for water,gas, electric, telecoms, etc.. all run on the walls. they dont need to dig up road again as its all accessible within. makes so much sense. There are similar in Denmark and parts of Germany
Even the soviet block managed similar, when visiting Moldova, they had shared utility tunnels, albeit homeless youths and families lived in them!
Seems us being an 'advanced' western nation and all have failed to grasp the benefits, especially on new builds.
Reply to Electric Cable & Gas Pipe In Same Trench in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I'm currently building an island in my kitchen which will contain a gas hob. I've cut a trench about 60mm wide from the edge wall to...
Hi Guys Would I be correct in thinking an electric cable can be as close as 25mm to a gas meter ? (not that I'd ever be that close out of...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
