Discuss electric into garden shed in the UK Electrical Forum area at ElectriciansForums.net
I presume the green building is the shed?
Whats the brick building with the door open? Does it have electrics in it?
That takes me back to the day when Part Pee and the notification thingies came into force.
I was a regular on the IEE (now IET) forum then. I did have to smile at all of those time served and, probably, very qualified electronic engineers who bleated very loudly. When they realised that they could no longer do very much electrical work in their own houses!
This is the same for the likes of me who used to be a Q.S./P.D.H. for a so-called electrical contractor in Northamptonshire and dealt with the Part P notifications now I do commercial works ie schools etc also the likes of Pete999 who has had a lifetime of electrical installation works from house bashing to high profile installations. Now with part P, this means that we can't do some electrical works in our own homes without the expense of a third party or through L.B.C. And we would do a better job than most that are in one of the schemes from what has been posted on here for us to see.
Garage....by the looks.
Thats what I was thinking but wanted to be sure. Also the question of 'is there electrics in it' needs answering. maybe the OP could tap off it if there is.
Is it literally a wooden shed that you buy at the garden centre? There are fire implications if so. Is it a metal shed? If so then there are earthing considerations. Is you supply/house already RCD'd? It is not easy from the information given to confirm your plans are kosher. How far away is it from the house? In any event an RCD is going to be needed to be involved in this matter.
Yes green building is the shed...
building with door open is the garage...
garage has a double socket on the wall which is powered from a plug socket in the lounge. As you look at the lounge in photo, plug sockets are on the wall to the right of the open sliding doors. The mains lead is plugged in there, goes through the wall into a double socket in the garage.
Does your CU have RCD protection?
So your garage is using an extension lead for the power?
Temporary is a word to use carefully. The extension lead provides power and works but it shouldn't be left there - there are regulations on temporary supplies and an extension lead is not one. I would bite the bullet and have a shed installation fitted correctly then it's done.
How about extending the circuit from the living room into the garage and shed?
Even better would be a dedicated circuit, but that involves Part P, as it's a new circuit.
Reply to electric into garden shed in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi, I have recently moved house and what to replace the garden shed. The shed has some electrics; a double socket with a fused light switch and a...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
Hi Guys. Customer want to install some double sockets and few lights in new built garden shed which is 35 meters away from Consumer unit. I...
5K
