T
thekingiam
i live in south wales, my customer wants ten electric meters installed so each has own bill read by power company.who installs them how can i contact them?
).Buy the key meters from ebay, install them yourself, or get someone who can..... you will most likely need to spur them from your DNO supply which is easy if you are ok working live. You just daisy-chain them from the bottom of the Henly block.( as to not use other people electric).
Once you have have done that, contact Npower, etc, get them to come install the tails to the switches and register the meters and supply the keys and you are sorted. Saves you thousands!!!!
