Electric shower advice
thank you , they did offer for me to have it disconnected and return for refund pending investigation of complaints. I will contact credit card when I have send back to them as I will no longer have their shower. thank you
Hi Wilko,thanks for that, no shower before this,meant to update last night but got a bit involved watching solo with my youngest son.....anyway had time for further tests yesterday it turns out that the eco button micro switch wasn’t working correctly so the shower was stuck in 5.5kw mode, when then button was physically held in the water came through screaming hot and the amp reading jumped straight up to 36-38
Told customer she can either send the unit back or contact manufacturers for the part, thanks to all for replying as always
Hi, We have this exact same problem, just checked out the Echo button by holding it in as suggested and hey presto we have hot water coming through. Can you tell me how your customer resolved this issue in the end or is it still on going do you know? Thanks in advance.
Hi Tina
They will tell you that you need to fit a piece of rubber between the back of the eco button and the wall to stop the body of the switch from moving backwards and preventing it from engaging....my advice is to demand your money back and don’t deal with Victorian plumbing again, as they will also void any further warranty on the unit.
They will also not pay for someone to “repair” the unit leaving you further out of pocket.
As above I recommend my customers avoid the company like the plague!
Thanks for coming back to me on this. What a nightmare!
I wonder did your client go with a completely different make of shower in the end? Sorry to ask but I really am in two minds weather to get a replacement and take a risk that it will be fine or to start over again and change to another manufacturer ! So much hard work has gone into our new bathroom re-fit and this shower, sadly has let it all down.
Hi. We now have ours resolved. I gave them a choice replace it with another shower of our choice or I would go through section 75 via credit card for full refund
Now had a quick turn around and have a Mira excel EV which we are accustomed to sadly a hole to plug in our beautiful new shower wall. But we’re problem solvers do lesson learned. Good luck Tina
They do the same shower without the eco button, tell them you want that as the fixings are exactly the same so no holes left in ya wall, tell them you want some compensation as well as they know these showers are faulty, I contacted the manufacturers directly, LOUED consultants, who rather ironically offered me a contract to repair these showers around the south of England, they told me the part was left out at the factory.......I don’t believe that personally, they are just very poor design and for Victorian plumbing to continue selling them is a disgrace!
I’d contact watchdog.....
Hi Tracy, Thank you for the information. We paid through our bank direct so not sure where we stand but that would be another "Forum" I guess. Lesson learned indeed. I've not been in touch with V.
Plumbing yet, I need to calm down and get my head straight, I'm so angry right now as I guess you would have been too. Luck is what we need for sure, thank you.
Thank you, this is really helpful. I'll get in touch with them and see what happens.
Hi Baddegg, Got an update on this. We have had an e-mail from the manufacturers telling us the following....
The units are factory tested on a steel wall which is 100% flat.
We have found if the wall the shower is fitted to is 1 or 2mm out it slightly twist the back fixing plate causing the eco switch not to hold the microswitch down when pressed. Hence your issue mentioned below about the eco switch.
Firstly isolate power to the unit.
See attached document. The solution is to fit 6 flat washers underneath the three screws (2 PER SCREW) holding the back plate to the wall.
These screws go between the back plate and wall allowing the front cover to fully engage when fitting to the back plate.
The result is the eco button fully holds down the microswitch giving full power and a constant heat.
From anyone's point of view, will this actually resolve it?
Thanks in advance for any advice.
Hi Tina
Thanks for updating us, I’d say no it is not resolve it but it’s entirely your call really, personally I think it’s an extremely poor design and can’t see why a consumer should have to retro fit parts if the manufacturers know they could fail? There’s not a wall in this country that’s 100% flat and they know it, i advised my customer to change the unit for one without the eco switch but as i say it’s your call.
Update, I'm being told now by VP that if they collect the unit for a refund there's no guarantee that we will get it, because if the manufacturers find nothing wrong with it then they won't refund! I have now had an e-mail from the manufacturers giving me dates of when they can come and fix the problem by sending in one of their men, but I have to sign a T & C which states that if the unit has been installed incorrectly in any way then the cost will be down to us! I am loosing the will to live, because I can see that they will use this 1-2mm flat wall issue that they mentioned before. Anyone got any legal advice, I'd be grateful. Thanks.
