Discuss electric shower tripping in the UK Electrical Forum area at ElectriciansForums.net
You don't need all singing, all dancing test gear, the vast majority of fault finding jobs can be done with a simple megger.
There's a good reason that the practices of 40odd years ago are no longer acceptable, they are dangerous and have been responsible for many injuries.
Megger Dave tut tut next you will be telling us you use a Hoover:D
????? To the above.
When you say you've got a Fluke, do you mean a multimeter ?
yes, yes...but fluke were the gold standard in my days multi meters are available for less than a tenner these days
????? To the above.
not sure what the ???? are but if we needed to test an installation we asked for the megger not the insulation resistance tester it came in a nice grey leather case and had a wind up handle
yes ..just clicked, I suppose all forums on tinternet are the same...I'll leave you all now and get on with the rest of my life (retired public sector :)
But thanks for the help
N
The question marks were in reply to your post about knowing what they were called, after Westy joked about Dave telling us to use Hoovers.
As for the fluke, don't really think it's going to help you out here.
Yep know all about wind up Meggers, still had one until a short time ago. Cut my teeth with fault finding using a Drummond probe, Avo 8 & Megger. The Avo & Megger had to be signed in / out of stores every time.
Oh & don't forget the ubiquitous neon screwdriver.
Wonder if the OP is charging for this?
So its a recent install, the customer bought the kit, the installer isn't returning calls, the OCPD may be too low, we don't know if the RCD or MCB are tripping.
We do know the person fault finding doesn't have the appropriate kit.
Has it ever worked?
Did the installer provide a cert?
Wonderful!
Q
Has it ever worked?
Wonderful!
Same old story buddy, nothing changes :)
Reply to electric shower tripping in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Went back it a house after they upgraded shower to a 9.8kw, pulling 40a constant. We had wired it with 10sq and 40a RCBO. 10sq Neutral cable...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
