J
Julian hull
Hi,
I have recently moved into a rented property, there is an electric shower installed and it look fairly new however when in use it keeps tripping out, on inspection the shower is a Mira 9.5Kw. underneath the main consumer board there is a separate one installed for the shower that has a 40A RCCB with a 32A MCB, the shower has 6mm cable running to the shower consumer board and 6mm running from the shower consumer board to the main consumer board, the main consumer board has 4 number MCBs fitted for lights, sockets, cooker & water heater and there is also another cover that has a 50A fuse fitted and this is marked as heater as ther is blow air heating, but im not sure what the shower is wired to, is this the correct set up?
