techguy
- Reaction score
- 0
First of all, am I allowed to do work myself? I would say I am fairly competent and I absolutely respect the dangers of electricity.
I have a small shed, which I want to put two 10W LED flood lights and a 13A socket on the side of.
There is no mains supply to the shed and I was thinking of putting a leisure battery in the shed, which will be charged by a small solar panel on the south facing side of the roof.
A 1000W inverter connected to the battery will supply a CU.
CU will contain two MCB's (one for the lights, one for the socket). Both will be fed from a 30mA RCD (it's no worry if one circuit trips the other).
As I am using a 1000W inverter, the outdoor socket will be fused at 3A. It will only be use to power a fridge or other low power devices such as other LED lights.
LED flood lights on the shed will be individually switched by a double switch. All outdoor equipment will be IP67 obviously!
For safety I intend to have isolation switches between:
solar panel and battery
battery and inverter
inverter and CU (outside shed)
I don't believe the AC supply from the inverter will be earthed (I can't see how it would be as there is no provision for an earthing rod or anything). Is this acceptable considering the circuits will be RCD protected?
Also, which size wiring should I use for everything? Is 1.5mm fine or should I go smaller? Can I just use twin and earth for everything? For the connection between the inverter and CU (through isolator switch) I was going to use a lawnmower power cable with the end cut off and a 3A fuse in the plug too.
Everything will be sufficiently labelled and there will be warning stickers everywhere! Note that the entire install aside from the actual LED lights, socket, and isolator switch will be inside the shed which is locked and only I have access to.
Thank for all your help, tips etc.
