M
Marvo
If Hobsoni has just dumped this problem and doesn't come back with an answer I'm going to be depressed
This do you?
I'm using a seperate cable from switch 2 (all settings) to each lamp. Same as switch 1. I'm also (probably wrongly!) that Switch 1 is live, switch 2 is neutral....can't work out what you mean Elmer.
I like the way you're thinking but in position 4 the 3 lamps are in series so they'll be dim.
I'm getting a serious pain in my head now as well.
P.S. Looks like your sketch!!
Morning gents,
It is possible, apparently there is also a second way too. Although my boss only knows of the one way. I have spent considerable amounts of time on this problem myself, it makes me question my ability!
PS: I spoke with Tony regarding the problem and he said only one other person he gave this to solved it, that was 35 years ago...................he was working in Algeria showed it to another Engineer who thought about it for 5 mins and then drew it out in the sand.............cocky sod!!
Yes, one switch provides the live and the other switch the netutral.......................just like a normal circuit. There is no regs involved, just try and get it to work. It has been rigged up and tested by the way, it works.
Good luck
Morning gents,
Good luck
