• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Electrician for outside power in Gloucestershire in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Evening,
Having some garden work done and need an electrician to finish it off. Already have power in the garage which comes direct off the main fuse box and on a concatenating wire, so hopefully this work can come off that supply with no need to bury anything.
Looking to add two bulkhead style lights on the exterior garage wall with exterior switch, a double exterior socket, and some switched festoon lights. Possibly also swapping a white plastic socket in the kitchen for brushed steel.
Reply to Electrician for outside power in Gloucestershire in the Electricians Jobs area at ElectriciansForums.net
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
Hi, I’m new to the forum and am seeking some advice please. I’ve picked up a job that another electrician has abandoned, the job is to...
I need to handle power failure for my electric strikes in my house. Of course, I can leave the keyed entry on the knobs, but what if I wanted to...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
