How to find the default "Username Password" for Enecsys Gateway from your local network using local IP as you can on a standard router not connected to enecsys yet.
We didn't have to log into the Enecsys Gateway at all. It picked up an IP from the local network's router and then just sends its information out to Enecsys.com. You do all the array configuration etc at the Enecsys website
Got it Username : admin
Password. : password
This is from your local ip 192.168 .1.71 or what your local ip is.This gets you into the Ethernet gateway settings DHCP settings Zigbe network Home etc all locked inside that tiny box.
Yes did read the manual no info on the above. Try it let me no
Enecsys Gateway CG-A-AB -EU -1
Thread Tags
Brmbaz,
Brmbaz,
