Discuss Enecsys Gateway CG-A-AB -EU -1 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Brmbaz
How to find the default "Username Password" for Enecsys Gateway from your local network using local IP as you can on a standard router not connected to enecsys yet.
We didn't have to log into the Enecsys Gateway at all. It picked up an IP from the local network's router and then just sends its information out to Enecsys.com. You do all the array configuration etc at the Enecsys website
Got it Username : admin
Password. : password
This is from your local ip 192.168 .1.71 or what your local ip is.This gets you into the Ethernet gateway settings DHCP settings Zigbe network Home etc all locked inside that tiny box.
Yes did read the manual no info on the above. Try it let me no
Reply to Enecsys Gateway CG-A-AB -EU -1 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
CityElectricalSupply.com (CES) are an electrical supplier across the United States with over 550 branches coast to coast. Here in the UK we...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
