Discuss ES replacement for BC Lampholder in the Electrical Tools and Products area at ElectriciansForums.net
Didn't ever say I can't get the LED lamp(s) that I want in BC fitting. Just ES fitting LED lamps are much more readily available. The BC fitting is less commonplace over all and I'd like to make our light fitting more future proof.
Reply to ES replacement for BC Lampholder in the Electrical Tools and Products area at ElectriciansForums.net
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
I'd like to refurbish the alternator for a 2005 CR-V. My plan is to replace the front bearing (the one closest to the alternator pulley) since...
765KV GIS Circuit breaker without PIR is in service. In case of any problem in one of the pole, Can I replace the same with 765KV CB pole with...
Hi, does anyone know where I can buy a replacement light fitting like the one in the picture? It takes a s15 bulb 284mm and the length can be no...
