Hi members
Eurotherm Drive 620 Vector link -which turns on a winder. Trouble is potentiometer just turns on the Winder but extremely slowly and speed does not increase when potentiometer turned. Checked potentiometer and it’s ok - voltage variation out of it is fine.
Do I need to programme the drive to have speed increased when potentiometer turned? If so how do I go about in the drive to set this.
Thanks in advance
Is this a new issue ie it worked before or have you added the pot' and want it to be manually speed controlled?
When we programmed any vfd drives we always kept a copy of the parameters for the equipment.
Easy way to correct anything that someone changed.
Birmingham
Business Name
ABC
Eurotherm Drive 620 Vector Link
Talk Electrician Forum
Thread Tags
Tags Tags
drive
Kootni,
gnuuser,
