Hi all
No questions really just interested to show a few DIY projects I've been working on to improve layouts and cabling of my consumer units, and adding a 7Kw wallbox outside for my EV.
Main consumer unit (3 phase - no nuetral - 230v L1/L2/L3) - additional CSU next to it for UFH
2nd consumer unit on the 2nd floor.
Issues found - several wires twisted and stuffed into the outlets of the MCB and RCD! Exposed copper on main feeds and others.
Upstairs Under Floor Heating wasn't actually going through any RCD, downstairs was.
Added 3 distribution blocks (very hard to find in Uruguay) on the main downstairs CSU (acutally 2 next to each other - extra one for the UFH. To organise all the cables.
So 3 phase comes now into the blocks and separates the power up to the upper floor, also to the UFH 2nd CSU downstairs and a couple of other separate fees (exterior).
Ferrules added to almost all terminals, still a few remaining to do. They were a mess with exposed strands etc, My OCD kicked in everytime I walked past the units.
7Kw wallbox installed outside, took this directly to the main MCB next to the meter with an isolator between this and the wallbox MCBRCD protection. Nice neat ducting along the wall around the carport to where the wallbox is
Had to install a new Exterior unit next to the meter (rated IP66) CSU as the old one was in bad shape (plastic crumbling from sun damage and no seals left) and too small.
Added 3 Wago distribution blocks, slim vertical great for the limited space in the exterior unit - can feed the wallbox with the isolator from these.
Just a quick short story! Been ages since I've been on this forum.
Ok it's not perfect yet, sitll some improvments to make. Will update and listen to any constructive critisicm.
Thanks all
Thanks all
