Discuss Extension Lead Setup in the DIY Electrical Advice area at ElectriciansForums.net
kixyyyyy
If i were to use this Surge Protected 8 Plug extension lead with individual switches, could i plug 4 plug extension leads without switches into them? For this setup, the power is only going to small consoles. I want it to be as easy to use as possible, so I wanted to have the 8 Plug Extension lead as a kind of hub, and the 4 plug extension leads powering each console. Of course only one of the switches would be on at a time.
Please look at the images attached to see visual
Reply to Extension Lead Setup in the DIY Electrical Advice area at ElectriciansForums.net
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
