Discuss Extent of installation covered.... in the UK Electrical Forum area at ElectriciansForums.net
leep82
Recently been pulled up by the QS for the company i am subbing to regarding a few issues with my test sheets. Theres nothing major and most of it is just mis entered information as its the first time i have personally used the niceic online software so only just getting tongrips with it. One thing i was pulled on as you might guess from the thread title was what i entered in the ' extent of installation covered by this certificate '.
The certificate in question was for a number of new circuits to an existing installation, ring final circuits, radials feeding fcu's for various equipment etc etc. In the past for a company i used to work direct to, quite often i would fill this section in with somthing along the lines of ' circuits as described on attached schedule of circuit details and schedule of test results ', and the QS would be happy.
I can only assume that the QS in question now isnt happy with this and requires more detail, but how much is enough and what is not enough? Its only a small section and when installing multiple circuits such as in this example surely its not practicle to list every new circuit. By referring to the attached schedules i would hope that anybody who views the certificate in the future or if there were any problems with other parts of the installation it would be clear as to what i actually worked on.
Just put what you've carried out
Such as new ring final circuit to ground floor sockets etc or wherever it covers
New radial circuits for .........
New consumer unit (if applicable)
Installed Main Protective bonding conductors to gas/water.
Just a brief but clear description
I suppose its all open to interpretation. If i had only installed one new circuit i would state that this circuit was the extent of installation covered. However ( and i think what i have been doing came from my course tutor when i did my 2391) , i dont see much wrong with how i fill this section in. All the circuits along with the relevant information are documented later in the certificate.
Reply to Extent of installation covered.... in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hello, I am in the process of training to be an electrician and have a question. When filling out a EIC for a new circuit am I required to test...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
