Hi All,
Were currently having a rear extention being built, after we will be having our garden landscaped. Our garden is on two levels, the steps and retaining wall will be made of timber sleepers with the top one having a slight overhang and I'd like to put led lights on the underside.
I've not had any previous experience with LED tape, question is what's the best way to discretly house and terminate the transformer/tape and what product would you recommend?
Dunk
Schluter do all sorts of profiles, highly recommended as are their 24V LED tape and transformers, the transformers have to be housed in a waterproof area: Schluter Liprotec PB-AEEB Lighting Edge Profile - Brushed Stainless Steel Effect (Select Length) - https://lilleytileandstone.co.uk/schluter-liprotec-pb-aeeb-lighting-edge-profile-brushed-stainless-steel-effect-select-length.html
[automerge]1586447333[/automerge]
You will have to study their products a bit as they do different profiles with different lens's to allow downlight only or downlight and projection and different tape LED's to suit, it's not difficult, just takes some time.
Wiltshire
United Kingdom
External LED tape termination
Dunk17,
Mike Johnson,
