Discuss Extra power points in the DIY Electrical Advice area at ElectriciansForums.net
Hi there new here I have been fitting a new kitchen and I want to extend the power supply in kitchen we only have one double socket on one wall and one on another. So I am wanting to ad a single socket below work top for washer with an fcu above work top to isolate. And the same for gas oven so what I am looking at is adding 3 extra double sockets and two singles I also have an extractor hud that needs power to I know about over loading that’s why I was adding fcu’s but with only having one socket on that wall and only been able to have 3 wires f
Get a sparks to do this work. See far too many dangerous situations as a result of incompetent persons carrying out this kind of work.
Agree
I always think that this is more than DIY eg adding an extra socket.
Other than a vague description of what you seem to intend to install,what is your question or point ?
a separate rfc for the kitchen is my advice, get a local sparks to quote.
Reply to Extra power points in the DIY Electrical Advice area at ElectriciansForums.net
I have a single wall switch powering 1 light and I want to add a separate light and change to wall switch to a double to power them both...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
