O
Olec
Hi all, hoping someone can help. I was called to a bathroom ceiling mounted extractor a couple of months ago in a top floor flat that was dripping. On inspection the duct had come away from the tile vent so I reconnected and advised them to keep an eye on it. It's dripping again and I have said the only thing I think it could be is the hot steam hitting the cold duct in the attic and condensating. I've suggested adding an inline fan in the middle of the run as well as keeping the existing fan and also lagging the duct with some fibreglass insulation. Can anyone see an issue with this or has a better idea?
either that or put a bucket under the fan.
do as a backi up if the bog gwts blocked.
The condensation dripping might be eradicated if you use a fan with an adjustable overrun timer or even add an overrun timer separately.
Thanks all. I am not going to add another in line fan because as said this is an expensive experiment. I have ordered 3m of pre insulated duct and will have to hope this works. I like the look of the condensation trap but not sure if there is access to the soffit and I can't get to it from outside (4th storey flat)
