- Reaction score
- 19
Hi everyone, did some insulation testing on my mates house as his RCD was tripping manage to isolate it to the ring circuit, Live-Earth for the ring circuit came to 0.01Mohms and all appliances have been disconnected and removed.
However I have disconnected the Live-Earth behind one socket (Socket A) in order to split the circuit and with the process of elimination work out and get closer to where the fault is.
I got readings of >900 for another socket in the same room (Socket B) but when i reconnected the Live-Earth in that Socket A and tested Socket B again just to make sure the reading fell to 0.03Mohms.
Theres no clear correlation to which sockets are ok and which aren't for instance there are four double sockets in the living room all will have a reading of 0.03Mohms but one will be >450Mohms and the dining room next door also has 4 double sockets and two have given a low reading of 0.02Mohms and the other two have >550Mohms, any ideas?
Thanks in advance.
Mark
Thanks in advance.
Mark
