Discuss Fibre glass steps on roofrack in the UK Electrical Forum area at ElectriciansForums.net
sparkdog
I just wondered what others think of keeping fibre glass steps on the roof rack.I see a lot of vans with them on the top but but I would have thought weather would cause corrosion and also danger of having them nicked.I keep mine in the van but they take up a lot of space.
the only problem ive found with fibre steps is be careful how you clamp them on your rack,they can crack if clamped to hard at the weaker end or near a bracket ,other than that make sure there padlocked on or they will walk..i keep a little pair of 4 treads in the back soley for working in domestics or nice offices,nowt worse than pulling out a pair of steps on mrs smiths nice cream carpet with steps covered in crap and drippping wet..
Why are fibreglass step ladders so popular? I can see their benefit in some industrial locations, other than that I don't see the benefit?
Mine are certainly more solid than it's ally equivalent, also being electricians I guess it sets a good example to not be standing on a rather large conductor :lol:
If people prefer them that's fair enough. As for the metal ones being conductors, safe isolation should cure that, but it would only be an issue if you were working with live cables which didn't have a CPC surely?
theres plenty of sites wont allow metal steps,i was working on a panel in a shop once and it was a mess in the leccy cupboard,tails and cables everywhere,rams said no metal steps..no work till fibre steps brought for job..
Are you serious how can GRP corrode?
I don't think it's such a silly question. GRP boats don't last forever. If the gell coat crazes and water gets inside, freezing would certainly cause damage. I would think that a ladder that was outside all the time wouldn't last as long as one kept indoors, although I couldn't put numbers to it.
If you live or work close to the sea, as I do, the issue is corrosion of the aluminium treads and rivets, in particular those that are pop-riveted. The pop-rivets suffer from galvanic corrosion due to the dissimilar materials (aluminium/steel) regularly bathed by salt-water precipitate. We find that GRP steps and ladders made by the Clowgroup, which use solid aluminium rivets, suffer the least in this adverse environment.
http://www.clowgroup.co.uk/laddersdirect.htm
Yes it was more the steel bits corroding I was thinking about.Both my step ladders are Clow.Thanks for the replies I will get some clamps and put the big ones on the roof.
Reply to Fibre glass steps on roofrack in the UK Electrical Forum area at ElectriciansForums.net
Hi guys I’m at one of the funny times in my career where I can’t decide on what I want to do. I’m wondering if one of you experiences folks can...
Hello all, was supposed to be running a bit of 6 mm swa along outside of building for a shed. My plan was just to clip it along wall above ground...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
