Discuss fibre optic star lights in the UK Electrical Forum area at ElectriciansForums.net
Try not to crowd them together , i did the first attempt and ended up redoing them again .
If you put them on a cheap ceiling fan remote controller from one of the sheds , you can not only alter the speed of the colour changing / twinkling disk but also dim the light down as well .
I put this one in my daughters room about six years ago and then got a locall artist to do the galaxy / sky .
I had a similar job a few yrs ago. Stud ceiling going up in a receprtion to a old peoples home and 4 of these were put in. only a 100mm gap between boards and old ceiling.The difference was it painted before it went up then holes added and fibers brought through. then tape jointed once back on ceiling and rubbed down on joints and painted over joints. worked well.
Reply to fibre optic star lights in the UK Electrical Forum area at ElectriciansForums.net
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
OK. I can already feel the eyes rolling I am working in a yard where we are having trouble with vandalism. There is absolutely no way of getting...
I have a ring cct (2.5mm ) in my cabin which is protected by a 20amp RCBO. This has been in existence for over 3 years with no issues. I recently...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
Heeelp! I have an 11kW/21A motor which is attached to a hydraulic power pack. I have replaced the old panels with new, using the same star delta...
