Hi all.
I’m looking at buying a PAYG tracker with ---- off option.
I need to wire the unit to live, neutral, the ignition and then to a relay which can shut off the power to the starter motor.
I have just bought a Range Rove Evoque 2013 and wondered the best way to pick up the starter motor cable. Would there and could I pick it up from the fuse box in the glove box (if it’s in that one) and cut that and connect to the relay?
I have push button start so what effect will it have when I push the button as I guess the old manual key crank system would just keep trying to turn over unsuccessfully. Will this do the same or just do nothing?
Thanks in advance.
We’ve.
Thanks in advance.
We’ve.
