Discuss Fixing backbox to aircrete / thermalite in the UK Electrical Forum area at ElectriciansForums.net
Deleted member 112675
Hello All
When fixing a backbox to soft airated blocks like aircrete etc, do you use special fixings or is a pair of normal brown plugs typically good enough ?
Thanks in advance.
1.5 x 10 screws into the correct plugs - solid as a rock
Hello All
Thanks in advance.
Dampen the hole you have cut for the box:
Drill some fixing holes:
plug and add some long fixing screws:
Whack in some Compo (BRICKIES MUCK) remove long screws. set box in said Compo reset some screws, make sure box is level , fill in the rest of the hole with Compo, wait until Compo has set tighten screws and Bob's yer Uncle, or in this case box fitted.
make box cut out dead tight then fit box with hammer. :p :p :p
I used to use no.8 1 1/2" screws with red plugs.... for years... then I watched another spark plowing screws straight into the blocks with no plug.... that's rough I thought.... but having tried it it holds aswell as plugs! Tends to be rendered in pretty soon after so now that's what I do
Reply to Fixing backbox to aircrete / thermalite in the UK Electrical Forum area at ElectriciansForums.net
Today I went to fix a minor loose screw on something and after switching off, etc, got out my Martindale VT12 continuity & voltage tester and...
Hi all, I am an experienced DIY electrician and I just wanted to ask a quick question about something since I am new to this forum, if it hasn’t...
My customer wants to fit round sockets and switches. He has sent me a link to the back boxes that are required. A few questions.. 1. Has anyone...
4K
Hello fellow electricians, Would anyone know how to connect a Nalder Bros & Thompson LTD London, please? ~The BS 89 is a tough book to obtain. I...
We have a customer in a large office block with all power in the building fed from an Electrak plug in busbar system. Lots of desks, lots of...
