Discuss Flammable Filler In meter Box in the UK Electrical Forum area at ElectriciansForums.net
timmmmy42
Hi, our new home builder has just repaired a hole in the our meter box using car body filler which I believe is flammable. The filler in cases the high voltage wires. I was wondering if this is dangerous and or a fire hazard?
Once it's cured it will not be flammable. However I'm not sure how the PVC insulation will react with the chemicals within the filler.
Are you sure it's car body filler?
honestly, I doubt it will ever be an issue.
most 2 pack resins are designed to react with themselves then cure to be non reactive.
if you are concerned, ask for the mtds for the filler they have used (Material Data Sheet)
Reply to Flammable Filler In meter Box in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Very much a novice when it comes to electrics. Anyway, we're getting an EV chargepoint installed, but before we do, I was wondering what...
We have a meter EDMI - ES30B fitted to our property. I understand from the fact sheet for the smart meter...
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
