Discuss Flat wire strippers C.K and Jokari in the Electrical Tools and Products area at ElectriciansForums.net
ferg
Patron
Has anyone tried the ck or jokari flat wire strippers?
Also thinking of the jokari flex strippers?
If so what did you think?
I use the Knipex 'dismantling tool' (catchy name!), and it is excellent. The time saved when dealing with flex is fantastic. And no more risk of slicing my fingertip off, which is nice!!
I went for the one that costs around £25 I think, have tried it with different sized flex, and also with some T&E, great results all around. Obviously need to check insulation afterwards for any nicks, so far so good.
EDIT: I just saw that you were looking at flat cable strippers. If you hit the flex with a mallet a few times it will be flat.... ;-/
Flat wire ones are a waste of money IMO as pliers or snips are quicker, but round cable stripper from jokari is brilliant don't know how I ever survived without it now
I occasionally use a flat wire stripper when I have lots of the same cable to strip, it is neat and quick but does not always strip all cores at once and if there are any short bits of insulation still in the stripper it fails miserably. Makes a neat end to the sheath, but with pliers marks on it.
Jokari Flex stripper is very useful and I always use it for RR flex but it does not manage 1mm 3 core easily as the flex is smaller than the space and the depth of cut can hit the inner cores on the thinner sheaths, I have stripped down the length of the flex and then peeled back to find a neat slice down the line insulation as well!
I have a set of the CK ones, which I rarely use - I use this one
For T&E I find they make a really tidy job of it BUT I don't use them for that - the earth sleeving doesn't stay on as well as it does if you use snips.
I use them for flex, the one I have linked to does 1.5mm, the CK one is too narrow for it. They can even do that crappy flex you have to deal with in customer supplied light fittings with total ease.
Had the Jokari for flex and a separate Jokari that was for coax, both decent, I've never used the flat wire strippers but going off the other products they make I'm sure they will be decent
Reply to Flat wire strippers C.K and Jokari in the Electrical Tools and Products area at ElectriciansForums.net
Hi guys Can anyone recommened a decent cable stripper for flat and 3 core cables? Here's a couple ove seen online...
Has anyone come across automatic strippers to pull of the sheath of a cable already in a back box. The regular ones can do it to a degree but due...
Good evening all. I have a couple of learners with hypermobility issues - which causes their hands to be sore after a day in the workshop. Has...
I always find stripping round flex a bit of a pain. I nibble away at it, bend it forwards, backwards, sideway and eventually it comes off...
