Thanks, that will be why my wander lead was coming up with higher readings
Think ill just go and play with the traffic for a bit
you sod!When your doing the insulation resistance test, be sure to test the meter on a known source first. The best way to do this I have found it to hold each tip in seperate hands and test, anything under a meg andf your fine. Let us know how you get on.
Rich
Dont forget to make sure its 100% by getting them wet first, our app did it with dry hands and got funny readingsWhen your doing the insulation resistance test, be sure to test the meter on a known source first. The best way to do this I have found it to hold each tip in seperate hands and test, anything under a meg andf your fine. Let us know how you get on.
Rich
