Has any used the Fluke 1653B yet?
The all new Fluke 1654B multifunction tester is an excellent downloading tester, with time saving features that fill in the relevant fields of your test certificates, when downloading to the Fluke DMS 17th Edition software. This new model greatly improves on the Fluke 1653B, with the addition of an extended memory for storage of up to 1500 test results. Another unique feature is the 0.001Ω resolution on the high current loop test and full RCD type B test (smooth DC currents).
A large backlit display makes it easy to read the test results and all testers are supplied with fused test leads, remote switch probe, certificate of calibration, carry strap, quick start guide with full instruction manual on CD and a hard carry case.
  • Performs Insulation test at 50, 100, 250, 500 or 1000V.
  • Non-trip loop test won't trip out RCDs, and now the B version also includes a high current loop test.
  • 0.001Ω resolution on high current loop test
  • Auto RCD test, Ramp test & RCD trip time test with variable RCD current mode for customised settings & Pass / Fail indication.
  • RCD Type B Test (smooth DC current)
  • PEFC / PSC (PFC / PSCC) & loop measurements are displayed at the same time
  • Earth resistance test (optional spike kit required).
  • Phase rotation.
  • Live voltage indicator and wiring polarity checker.
Hi, cant seem to operate the memory mode on my 1654b. Can enter memory mode but can,t figure out the memory set up. When i press store( so it records the next reading) i get an error tone and meter stays on memory screen not returning to test screen. This is prob a simple issue im doing wrong.
Help!!!
