Discuss Fluorescent light won't work in the DIY Electrical Advice area at ElectriciansForums.net
I have a light that stopped working. I thought it was the tube as it had blackened at each end. Got a replacement and the light still does not work. Is the ballast the circuit board pictured? If it is bad how is it replaced and with what? It is a beer light that I would like to get working again.
Reply to Fluorescent light won't work in the DIY Electrical Advice area at ElectriciansForums.net
One of the fluorescent tubes in my undermount lighting system burnt out. There are 3 independent tubes/ballasts under the length of the kitchen...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
Hi,
I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
I have a Security Light on my patio and until recently it worked fine.
It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi guys,
I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
