Offthewall
- Reaction score
- 0
Hi.
have a 1999 1.6l that won’t start.
has had an intermittent issue for a year where every so often it will lose power and just about stall then will swiftly recover. Went to start the other day and will crank but not start. Battery is good, cam and crank sensors tested and good. Fuses are good. I’m getting no ignition signal at coil and can not hear the fuel pump engage when turning key on. ECU signal tested and ok. Have swapped out the coil from a donor vehicle and no change.
its almost like I have a broken wire somewhere but I’m unsure where to start testing.
Any advice greatly appreciated.
thanks
thanks
