Mark you're obviously clueless mate, best jack it all in. I'll give you £20 for your van and your test gear :)
Just in case, that was said as a joke.
Deal.
Believe me, you're gonna wish you had viewed before purchased lol. M.O.T in April, if it's not near a grand i'll be amazed ha.
We were taught at college that if the armour is not being used as the earth, then only needs earthing at one end (supply end). If the armour is being used as the earth then it needs to be earthed at both ends.
IF your Job/Business revolves around these and associated documents then you should have them and access to them at suitable times.
If you can't be bothered to check things out then stuff you.
Literally everything gets left at my back door when i come in from work...and from where im sat now, to the back door is a good 10meters ... far to far with a hangover.
I understand, you're old school. Need not stay away from the forum just because of this thread, as that would be silly.
Nothing to do with that, he has his hair off because his sheep ran away lol, sorry Paul Just kidding :uhoh2:
obi wan has taught you well.
they didn't run away. des rustled them.
Isn't the armouring classed as an exposed conductive part whether or not there is a shroud covering the termination, so as such it has to be earthed, I'm sure I've read that somewhere.
Glad I didn't jack in with the forums looks like some good manly debates are emerging over the last 24 hours :45:
You were going to leave this forum?
You should have started a thread about that, we could have helped persuade you to stay then.
​That was a joke by the way.
Dillb I will presume you are joking as I did start a thread and I am glad to say some very nice members persuaded me too stay
