M
moldy1
Hi all, I am looking to put in a 20amp supply from my consumer unit over about a 20 metre run to allow for the connection of a hot tub... My current consumer unit has no available space for an additional RCB so my question is... can I make the connection to an existing RCD being used by say a ring/immersion heater or oven.. I suspect not... Do I need a new consumer unit with more space for additional RCBs or can I run a separate small consumer unit to accommodate a few more
They are several answers to your problem that a decent spark will sort out for you without any problem I'm sure.
additional CU or replace existing with a bigger one. your choice.
before you get the wrong idea, this forum is for sparkies so don't expect to be spoon fed the parts list and instructions on the install and how to deal with LABC
Dunno about that M., we are forever spoon feeding the Electrical Trainee brigade on here.
A very small hot tub then?
its like and RCD but an earlier version hence B not D, apparently an RCA used to be even better to use, you could cram them in any board without removing the cover lol
It's a 'like' from me but my phone doesn't offer the function!
My tub pulls 40 amps! What power rating is printed on the tub itself? I know some run on a plugtop though
