G
Geordie Spark
Seen a few on eBay mate.
I went to Whitley Bay but it was closed, so I thought about trying Morcambe Bay but can't afford the petrol on my pension.
Where abouts is E Bay?
i've got 10A. file it down a bit to get 8A
Now though you have too much girth
I use a strip of 8A foil.
Still like to know why the OP wants a 8A fuse.
Cross out the number 13 and write 8 instead
Oh dear oh dear. :frown::thinking::whatchutalkingabout:6:
Amp David, I have NEVER had a problem with girth, never had a problem with length either come to think of it.
That's what an ex-girlfriend once told me.
Just because I had a 38" waist.![]()
Plug it into a dedicated socket on a radial protected by an 8A MCB.
Simples.
Surely it would make a much neater job if you simply joined up the gaps on a 3 to make an 8!
Just use 2x 4A MCBs in parallel.Now thats got to be the best idea. Bugger, who sells an 8 amp MCB for a chint CU? Its ok i'll use one from a CED one instead.
I was going to use two fuses and selotape the plug top on
It doesn't say you can't use Blu-Tac - I've checked.Is there anything in the Big Brown Book that says I can't use cable ties instead of insulting tape?
I'm thinking the tape may lose its stickiness when the fuses get hot.
