Hi all, a friend has a new build and has had a towel rail fitted in the bathroom which is wired into a switched fused spur with a 3 amp fuse into which is inside the bathroom, the fused spur is outside all zones, but the confusing bit is, that fused spur is powered by another switched fused spur (13 Amp fuse) on the wall of the next door room which is not powering anything else apart from the fused spur in bathroom. Is this right ? I would have thought it would have been wired through a flex cable cover and connect to fused spur in next room!!
