Discuss Fused unit no longer required in the DIY Electrical Advice area at ElectriciansForums.net
I've just removed an old fused electrical heater fitted in the middle of the ring circuit and am now left with the hole and wiring (see pic). Ideally I want to just cover this up with a bit off plasterboard so it looks like nothing was ever there. Is it OK to do this or is this deemed unsafe? I could always turn it into a socket but there is one quite near it already so it might look a bit odd.
Would be really grateful for any replies.
No block connectors shouldn't be used like that, they don't provide a maintenance free connection.
Your idea of making it a socket is a better way.
You can't cover it up as is you need to use maintenance free connectors, even so turn it into a socket outlet, makes sense no big deal.
Yeah I guess I was hoping not to have to do this if possible because its right in the middle of the room and so will not look great. As I say, if it's not safe just to cover it with plasterboard, I guess I'll have to make it a socket...
Go to an Electrical wholesaler and buy an Ashley 803 or similar maintenance free junction box, that will fit through the hole. Then as Lanky said, fit a blanking plate over the hole.
If you fit a blank plate the earths will need connecting to the metal back box.
If he uses the blank plate method there's no need for maintenance free connectors. That said I'd opt for wago or thru crimps.
Reply to Fused unit no longer required in the DIY Electrical Advice area at ElectriciansForums.net
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
Just had an EICR done and C2 (dangerous) applied to 3-way consumer unit which is exclusively for 3 x Storage Heaters. Pic below. Yes its plastic...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
